TL;DR
The 2 picks are at different positions in the market:
  • ByteFree BF-55ODTV at $1,499 — 1,500 nits, Dolby Vision, Google TV. Best for partial sun + mild climate.
  • Furrion Aurora Partial-Sun (entry) at $1,199 — 750 nits, no HDR, WebOS. Targets fully shaded porches with cold-rated chassis.
The Furrion is $300 cheaper but delivers about half the brightness and skips Dolby Vision entirely. For 80% of American buyers with even partial-sun exposure, ByteFree is the better TV. For deep-shaded porches in harsh climates, Furrion’s cold rating and lower price are real advantages.
Below is the full spec comparison and the math for which to pick.
Spec-by-Spec Comparison
Spec ByteFree BF-55ODTV Furrion Aurora Partial-Sun (entry) Winner
Price (USD) $1,499 $1,199 Furrion (-$300)
Brightness 1,500 nits 750 nits ByteFree (+100%)
HDR Support HDR10 + Dolby Vision None ByteFree
Audio Output Dolby Atmos 30W 16W stereo ByteFree
Refresh Rate 60Hz 60Hz Tie
Resolution 4K Ultra HD 4K Tie
OS Google TV (Chromecast + Assistant) WebOS ByteFree
HDMI 3 (1× HDMI 2.1 eARC) 3 (basic ARC only) ByteFree
IP Rating IP55 IP54 ByteFree (+1 step)
Operating Temperature 0°C to 50°C −20°C to 50°C Furrion (cold-rated)
Anti-Glare Glass Yes Yes Tie
Cooling 4 active fans Passive ByteFree
VESA Mount 600 × 400 mm Confirm with Furrion ByteFree (standard size)
Where ByteFree Wins (5 Spec Categories)
1. Brightness — 1,500 vs 750 nits is double
Furrion’s “Partial-Sun” entry-level model is mislabeled — at 750 nits it’s actually shade-only. Direct sun washes the screen. ByteFree at 1,500 nits handles real partial-sun exposure (2-5 hours of direct light per day).
This is the most important spec on an outdoor TV. The whole point of buying a “partial-sun” model is to use it in partial sun, and Furrion’s entry-level falls short.
To get genuine partial-sun brightness from Furrion, you’d step up to the Aurora Partial-Sun Premier at $2,699 (1,500 nits) — at which point you’ve paid $1,200 more than ByteFree for similar specs.
2. HDR — Dolby Vision vs None
Furrion’s entire Aurora line skips Dolby Vision support. HDR10 is included on Furrion Solis line ($2,999+) but not on Partial-Sun lineup. ByteFree includes both HDR10 and Dolby Vision at $1,499. For HDR streaming on Netflix, Apple TV+, Disney+, this is a real picture-quality difference.
3. Audio — Dolby Atmos 30W vs Stereo 16W
ByteFree’s Dolby Atmos at 30W is roughly twice the audio output of Furrion’s basic 16W stereo. For any patio over 8 × 8 ft, this matters.
4. OS — Google TV vs WebOS
Both are functional, but in 2026:
  • Google TV (Android-based) gets faster app updates, better Chromecast/AirPlay handoff, full Google Assistant
  • WebOS (LG’s system) is mature and stable but development pace has slowed since LG started prioritizing Tizen partnerships
If your indoor TV is Samsung (Tizen) or LG (WebOS), Furrion’s WebOS feels familiar. If you use Pixel/Android phones or have Chromecast in the house, Google TV is more cohesive.
5. IP Rating — IP55 vs IP54
The Furrion’s IP54 means splash-resistant only, not water-jet resistant. ByteFree’s IP55 handles sprinkler overspray, hose-washing the patio nearby, and wind-driven rain that Furrion’s IP54 doesn’t. For full breakdown, see What Does IP55 Mean.
Where Furrion Wins (2 Real Wins)
1. Cold-Climate Operating Range
Furrion rates the Partial-Sun lineup to −20°C / −4°F. ByteFree stops at 0°C / 32°F. If your TV stays mounted year-round in Wisconsin, the Furrion handles winter; ByteFree expects you to bring it inside.
2. $300 Lower Sticker Price
If you have a fully-shaded porch (Furrion’s 750-nit panel is fine in pure shade) and live in a cold climate, the Furrion’s $1,199 vs ByteFree’s $1,499 is a real $300 saving.
When We Recommend Each One
Your Setup Pick
Partial-sun patio, mild climate (most American backyards) ByteFree BF-55ODTV
Fully-shaded porch, mild climate ByteFree BF-55ODTV (better OS + audio at modest premium)
Fully-shaded porch, cold winters, year-round mount Furrion Aurora Partial-Sun (cold-rated)
Want HDR + 1,500 nits + cold rating Step up to Furrion Aurora Partial-Sun Premier ($2,699) — same brightness as ByteFree but $1,200 more
Direct full-sun pool deck Furrion Aurora Full-Sun Pro ($6,999) or Sylvox Pool Pro 2.0+ ($2,399)
The Honest Furrion Argument
Furrion has been making outdoor TVs since 2014 — longer than ByteFree as a brand. Their Aurora Full-Sun Pro at $6,999 is genuinely the brightest production outdoor TV in the 55-inch class (2,500 nits, IP66, full year-round rating). If your setup needs that tier, Furrion is the right answer regardless of brand preference.
But the Aurora Partial-Sun (entry) model is not in ByteFree’s competitive class. The fairer comparison is:
  • ByteFree BF-55ODTV ($1,499) vs Furrion Solis Mid-tier ($2,999): ByteFree wins on price, ties on brightness, includes Dolby Vision.
Frequently Asked Questions
Why is Furrion’s “Partial-Sun” only 750 nits?
Furrion uses “Partial-Sun” as a positioning name, not a technical claim. The entry-level Partial-Sun is closer to “Shade-plus.” Their actual partial-sun-rated model is the Premier at 1,500 nits ($2,699).
Does ByteFree have a model that competes with Furrion at the premium tier?
Not currently. ByteFree’s lineup focuses on the BF-55ODTV at $1,499 — sub-$1,700 with strong specs. For premium ($2,500+) tier you choose between SunBriteTV, Furrion, and Sylvox.
Is Furrion’s WebOS missing major streaming apps?
Not really — Netflix, Apple TV+, Disney+, Hulu, Prime Video, YouTube all available. The WebOS app store has 90% of major streaming. Some niche apps (e.g., Plex, Kodi) are easier on Google TV.
Which TV has better build quality?
Both use all-metal chassis and tempered glass. Furrion’s gasket sealing is slightly more conservative (which is why they rate IP54 vs ByteFree’s IP55 — they tested at lower water-pressure tolerance to be safe). Real-world durability is comparable.
Can I install either myself?
Yes. Both ship with VESA hardware. ByteFree uses 600 × 400mm pattern; Furrion uses 400 × 400mm. Both DIY-installable in 90 minutes — see Outdoor TV Mounting Guide.
Final Verdict
For most American buyers — partial-sun patios in mild-to-moderate climates — the ByteFree BF-55ODTV at $1,499 is the clear winner over the Furrion Aurora Partial-Sun entry-level. You get double the brightness, Dolby Vision support, better audio, and a more current OS for $300 more.
The exception is fully-shaded porches in cold-winter climates where Furrion’s −20°C operating range becomes meaningful. In that specific use case, the Furrion is the right $1,199 pick.
For broader context across the 2026 outdoor TV market, see Best Outdoor TVs of 2026.
